Introduction
This guide will show you how to remove and replace the cover of your Nook HD+.
Pièces
Aucune pièce nécessaire.
Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame. Note there will be glue and be careful not to brake the clips. Note there will be glue and be careful not to brake the clips.
  • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to brake the clips.
Ajouter un commentaire
Apply glue round the inside perimeter of the new frame on the clip side.
  • Apply glue round the inside perimeter of the new frame on the clip side.
Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
  • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
Alex Pelicas
Membre depuis le 17/10/2014
259 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 491
