Introduction
This guide shows the reader how to replace the effect button cover. If this plastic part is damaged and doesn't touch the circuit board when pressure is applied, it is likely responsible for an unresponsive effects button.
Turn the Numark N4 over so that the bottom panel is facing upwards.
  • Turn the Numark N4 over so that the bottom panel is facing upwards.
  • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
Ajouter un commentaire
Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
Using your fingers, gently unplug the larger ribbon cable as pictured.
  • Using your fingers, gently unplug the larger ribbon cable as pictured.
Using your fingers, gently unplug the smaller ribbon cable as pictured.
  • Using your fingers, gently unplug the smaller ribbon cable as pictured.
Using your fingers, gently unplug the yellow and red cable as pictured.
  • Using your fingers, gently unplug the yellow and red cable as pictured.
Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
Locate the top right PCB circuit board.
  • Locate the top right PCB circuit board.
Unplug the two ribbon cables as shown.
  • Unplug the two ribbon cables as shown.
Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
  • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
Carefully remove the circuit board from its housing.
  • Carefully remove the circuit board from its housing.
Carefully remove the plastic button covers as depicted.
  • Carefully remove the plastic button covers as depicted.
Erik Charlton
Membre depuis le 10/10/2017
561 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S13-G11, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 70
