Aller au contenu principal
Numark TT1600 Audio Jacks Replacement
Ce dont vous avez besoin
  1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: étape 1, image 1 de 1
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Numark TT1600 Audio Jacks Replacement: étape 2, image 1 de 2 Numark TT1600 Audio Jacks Replacement: étape 2, image 2 de 2
    • Find the audio jacks located on the back side of the turntable.
    • Remove the screw located in between the right and left audio jacks.
  3. Numark TT1600 Audio Jacks Replacement: étape 3, image 1 de 1
    • Remove the back cover by pulling it apart.
  4. Numark TT1600 Audio Jacks Replacement: étape 4, image 1 de 1
    • Remove the grounding hardware located next to the audio jacks.
  5. Numark TT1600 Audio Jacks Replacement: étape 5, image 1 de 2 Numark TT1600 Audio Jacks Replacement: étape 5, image 2 de 2
    • Remove the ground screw and washers.
  6. Numark TT1600 Audio Jacks Replacement: étape 6, image 1 de 1
    • Remove the remaining nut and washer.
  7. Numark TT1600 Audio Jacks Replacement: étape 7, image 1 de 1
    • Remove the screw located on the back panel of the audio jack housing.
  8. Numark TT1600 Audio Jacks Replacement: étape 8, image 1 de 3 Numark TT1600 Audio Jacks Replacement: étape 8, image 2 de 3 Numark TT1600 Audio Jacks Replacement: étape 8, image 3 de 3
    • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  9. Numark TT1600 Audio Jacks Replacement: étape 9, image 1 de 1
    • Gently pull out the audio input jacks from the audio input housing.
Nikolai
Membre depuis le 10/12/11
254 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-14, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,377
