Aller au contenu principal
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: étape 1, image 1 de 1
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: étape 2, image 1 de 1
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: étape 3, image 1 de 1
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: étape 4, image 1 de 1
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: étape 5, image 1 de 1
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: étape 6, image 1 de 2 Numark TT1600 Belt Drive Replacement: étape 6, image 2 de 2
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: étape 7, image 1 de 1
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Nikolai
Membre depuis le 10/12/11
254 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-14, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 45
Total : 6,288
