Pièces
Aucune pièce nécessaire.
Unscrew the 7 6.4mm T5 Torx screws from back panel Use spudger to separate front and back panels Use spudger to separate front and back panels
  • Unscrew the 7 6.4mm T5 Torx screws from back panel
  • Use spudger to separate front and back panels
Ajouter un commentaire
The green grill is not screwed in so it can be pulled right out. The green grill is not screwed in so it can be pulled right out.
  • The green grill is not screwed in so it can be pulled right out.
Remove the 6 6.5mm T5 Torx screws. Remove power wires. Peel back copper tape and remove black and white wires.
  • Remove the 6 6.5mm T5 Torx screws.
  • Remove power wires.
  • Peel back copper tape and remove black and white wires.
Once all cables are removed, pull the battery apparatus out.
  • Once all cables are removed, pull the battery apparatus out.
2 autre(s) ont terminé cette réparation.
Andrew Barbanera
Membre depuis le 20/09/2014
321 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 membres
6 tutoriels rédigés
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 20
Total : 3,134
