Pièces
Aucune pièce nécessaire.
Unscrew the 7 6.4mm T5 Torx screws from back panel Use spudger to separate front and back panels Use spudger to separate front and back panels
  • Unscrew the 7 6.4mm T5 Torx screws from back panel
  • Use spudger to separate front and back panels
Ajouter un commentaire
The green grill is not screwed in so it can be pulled right out. The green grill is not screwed in so it can be pulled right out.
  • The green grill is not screwed in so it can be pulled right out.
Remove the 6 6.5mm T5 Torx screws. Remove power wires. Peel back copper tape and remove black and white wires.
  • Remove the 6 6.5mm T5 Torx screws.
  • Remove power wires.
  • Peel back copper tape and remove black and white wires.
Once all cables are removed, pull the battery apparatus out.
  • Once all cables are removed, pull the battery apparatus out.
Cooling is important for electronics, the last thing they want is to overheat. Remove the two 7.3mm and four 8.4mm T5 Torx screws and remove the power cable. Once the screws and cable are removed, the fan can lift free
  • Cooling is important for electronics, the last thing they want is to overheat.
  • Remove the two 7.3mm and four 8.4mm T5 Torx screws and remove the power cable.
  • Once the screws and cable are removed, the fan can lift free
On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
  • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
  • Once removed, the display should be able to be detached.
3 autre(s) ont terminé cette réparation.
Noel Fletcher
Membre depuis le 22/09/2014
110 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 membres
6 tutoriels rédigés
Where can o get a replacement screen
jorge valenzuela - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 50
Total : 4,269
