Introduction
Use this guide to replace a broken keyboard.
Pièces
Aucune pièce nécessaire.
Turn the laptop upside-down, with the handle facing away from you.
  • Turn the laptop upside-down, with the handle facing away from you.
Ajouter un commentaire
Pull the lock tabs towards the green outer edges of the laptop. Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  • Pull the lock tabs towards the green outer edges of the laptop.
  • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
Lift up on the middle of the battery to remove it from the device. Lift up on the middle of the battery to remove it from the device.
  • Lift up on the middle of the battery to remove it from the device.
Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs. Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
Flip the laptop over to its normal position. Lift the two antennas on both sides to unlock the screen. Open the laptop.
  • Flip the laptop over to its normal position.
  • Lift the two antennas on both sides to unlock the screen.
  • Open the laptop.
Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom. Gently lift up on the back of the keyboard.
  • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
  • Gently lift up on the back of the keyboard.
  • Pull the keyboard up far enough to expose the ribbon cable.
Gently lift up on the black connector to release the ribbon cable. Gently pull the blue plastic tab up and away from the black connector.
  • Gently lift up on the black connector to release the ribbon cable.
  • Gently pull the blue plastic tab up and away from the black connector.
  • Remove the keyboard from the laptop.
Michael Kellerman
Membre depuis le 24/01/2013
46 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-30, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 480
