Introduction
If the device is not working properly this could be due to a broken headset motherboard. Common causes for motherboard failures include being exposed to static shock, overheating, or component failure.
Remove front cover plate. Unplug the USB and HDMI cables from the Oculus Rift DK2. Unplug the USB and HDMI cables from the Oculus Rift DK2.
  • Remove front cover plate.
  • Unplug the USB and HDMI cables from the Oculus Rift DK2.
Ajouter un commentaire
Remove the four 3/8" Phillips #0 screws from the inner portion of the headset. Remove the four 3/8" Phillips #0 screws from the inner portion of the headset. Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
With the screws removed, gently pull the headband frame apart from the headset. With the screws removed, gently pull the headband frame apart from the headset.
  • With the screws removed, gently pull the headband frame apart from the headset.
With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead. With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
  • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
  • Read the next step before removing the faceplate!
Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures. Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
  • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable. Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
  • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
  • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
  • The headset should now be two separate pieces.
Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out. Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out. Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free. Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free. Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
  • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
4 autre(s) ont terminé cette réparation.
Adam
Membre depuis le 20/01/2015
565 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-5, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 19
Total : 1,516
