Pièces
Aucune pièce nécessaire.
Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws) Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
  • Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
Put a notice on here that the screws are very small and are easy to misplace while disassembling device. Also, while disassembling the device there was only one screw present, where the guide suggested there were three.
Curtis Reedy - Réponse
Before beginning, put a note that the camera should be turned off before proceeding.
Add a note at the beginning of the guide that there are a large number of small screws that should be separated as the steps are completed.
There's a capacitor .....watch out for it in every step.
BILL BOYD - Réponse
Remove the right side panel by pulling off the large silver piece.
  • Remove the right side panel by pulling off the large silver piece.
There is no reference to removing screws from the right side panel, where it is necessary to remove 2 screws to do so.
Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws) Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
  • Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
Ajouter un commentaire
Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
  • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
  • Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
Remove 3 screws from the front of the camera using a #00 screwdriver. Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side) Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
  • Remove 3 screws from the front of the camera using a #00 screwdriver.
  • Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
Wrong point of focus for the second picture. What should be in focus is very blurry.
Using a plastic spudger, lift up the black clips. Still using the plastic spudger, detach the gold connector strip and white connector strip. Using both hands, pull the camera apart into two pieces.
  • Using a plastic spudger, lift up the black clips.
  • Still using the plastic spudger, detach the gold connector strip and white connector strip.
  • Using both hands, pull the camera apart into two pieces.
There were multiple gold strips, so the one that needs to be pulled should be highlited in the picture.
in step seven pull up the black bar of the ZIF connectors before pulling out the white or gold ribbons
Using a plastic spudger, lift up the black clips. Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
  • Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
Remove 3 screws from the inside of the camera using a #00 screwdriver.
  • Remove 3 screws from the inside of the camera using a #00 screwdriver.
Using your thumb and forefinger, pull the lens piece straight out from the body of the camera. Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
Unscrew two screws on the right side of the camera using a #00 screwdriver.
  • Unscrew two screws on the right side of the camera using a #00 screwdriver.
  • Still using the spudger, detach the gold wire tape connectors from the logic board.
Unsolder the upper right and lower left wires to remove logic board.
  • Unsolder the upper right and lower left wires to remove logic board.
In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger. In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
  • In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
Unscrew 2 screws using a #00 screwdriver. Now lift the metal piece straight up in order to remove it. Now lift the metal piece straight up in order to remove it.
  • Unscrew 2 screws using a #00 screwdriver.
  • Now lift the metal piece straight up in order to remove it.
Pull on the white tab to remove the small logic board with the flash on it. Pull on the white tab to remove the small logic board with the flash on it. Pull on the white tab to remove the small logic board with the flash on it.
  • Pull on the white tab to remove the small logic board with the flash on it.
Pull out sliver button using your thumb and forefinger. Now remove small logic board out of camera casing.
  • Pull out sliver button using your thumb and forefinger.
  • Now remove small logic board out of camera casing.
Remove plastic flash cover using a spudger. Remove plastic flash cover using a spudger. Remove plastic flash cover using a spudger.
  • Remove plastic flash cover using a spudger.
Remove the flash bulb using a plastic spudger. Remove the flash bulb using a plastic spudger.
  • Remove the flash bulb using a plastic spudger.
Curtis Reedy
Membre depuis le 12/01/2011
255 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-4, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,987
