Pièces
Aucune pièce nécessaire.
Remove the 2 screws from the bottom of the camera
  • Remove the 2 screws from the bottom of the camera
Ajouter un commentaire
Remove the screw from the right side of the camera.
  • Remove the screw from the right side of the camera.
Remove the two screws from the left side of the camera
  • Remove the two screws from the left side of the camera
Separate the front casing from the back using a plastic opening tool, gently. Silver band and buttons will become loose when you remove the two pieces. Silver band and buttons will become loose when you remove the two pieces.
  • Separate the front casing from the back using a plastic opening tool, gently.
  • Silver band and buttons will become loose when you remove the two pieces.
Pull the silver bracket and buttons off of the camera Pull the silver bracket and buttons off of the camera
  • Pull the silver bracket and buttons off of the camera
Remove the 2 screws on the right side of the camera. Remove the 2 screws on the left side of the camera. Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
  • Remove the 2 screws on the right side of the camera.
  • Remove the 2 screws on the left side of the camera.
  • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
  • Pull the camera apart into 2 separate pieces.
Flip up clip on circuit ribbon, carefully
  • Flip up clip on circuit ribbon, carefully
  • Detach the ribbon from the rear to the front and pull it out, gently.
You will be left with four major pieces
  • You will be left with four major pieces
Tracy Donovan
Membre depuis le 10/02/2012
13 Réputation
1 tutoriel rédigé
Équipe
James Madison, Team 3-3, Klein Spring 2012 Membre de l'équipe James Madison, Team 3-3, Klein Spring 2012
JMU-KLEIN-S12S3G3
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 372
