Aller au contenu principal
Pour réparer ensemble - Je crée un compte
OnePlus 6 Screen Replacement
Ce dont vous avez besoin
  1. OnePlus 6 Screen Replacement, Back Panel: étape 1, image 1 de 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    Demander à FixBot
    Ajouter un commentaire
  2. OnePlus 6 Screen Replacement: étape 2, image 1 de 2 OnePlus 6 Screen Replacement: étape 2, image 2 de 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Demander à FixBot
  3. OnePlus 6 Screen Replacement: étape 3, image 1 de 2 OnePlus 6 Screen Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    Demander à FixBot
  4. OnePlus 6 Screen Replacement, Battery: étape 4, image 1 de 2 OnePlus 6 Screen Replacement, Battery: étape 4, image 2 de 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    Demander à FixBot
  5. OnePlus 6 Screen Replacement, Speaker: étape 5, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the eight screws.
    • Carefully lift the speaker up and out of the chassis.
    • If you're completing a screen replacement, skip to Step 9.
    Demander à FixBot
  6. OnePlus 6 Screen Replacement: étape 6, image 1 de 1
    • Properly orient the new speaker unit and use a Phillips #000 screwdriver to replace the eight screws removed from the previous step.
    Demander à FixBot
  7. OnePlus 6 Screen Replacement: étape 7, image 1 de 1
    • Place the battery back into the phone and connect it to the same port, making sure to firmly press the connection down into place.
    • Place the red cover back over the top of the port.
    Demander à FixBot
  8. OnePlus 6 Screen Replacement: étape 8, image 1 de 1
    • Strip the existing adhesive, and place new adhesive around the entire perimeter of the back cover.
    • Replace the back cover and hold it down for about a minute to to let the adhesive set.
    Demander à FixBot
  9. OnePlus 6 Screen Replacement, Screen: étape 9, image 1 de 1
    • Use tweezers to gently pull away the tab securing the audio jack to the speaker assembly.
    Demander à FixBot
  10. OnePlus 6 Screen Replacement: étape 10, image 1 de 1
    • After removing the band, gently lift the audio jack out of the phone.
    Demander à FixBot
  11. OnePlus 6 Screen Replacement: étape 11, image 1 de 2 OnePlus 6 Screen Replacement: étape 11, image 2 de 2
    • Remove the white and black leads by gently lifting them up with tweezers.
    • Lift the band connector on the left side of the assembly up with tweezers to disconnect it.
    • Lift the band connector at the top of the assembly up with tweezers to disconnect it.
    Demander à FixBot
  12. OnePlus 6 Screen Replacement: étape 12, image 1 de 1
    • Using tweezers, lift the circuit board from the assembly and remove it.
    Demander à FixBot
  13. OnePlus 6 Screen Replacement: étape 13, image 1 de 1
    • Use a heat gun set to its lowest temperature, gently heat the perimeter of the screen to loosen the adhesive.
    • Wedge an opening pick between the screen and the chassis, then slide it around the entire perimeter of the screen to break the adhesive.
    • Gently pry the screen away from the chassis.
    • Reheat the perimeter as needed.
    Demander à FixBot
  14. OnePlus 6 Screen Replacement: étape 14, image 1 de 2 OnePlus 6 Screen Replacement: étape 14, image 2 de 2
    • After gently prying the screen from the frame, carefully thread the tab through the bracket to remove the screen from the phone.
    Demander à FixBot
3 autres ont terminé cette réparation.
2 commentaires de tutoriel
Works great, thank you very much. I changed the microphone with this instruction.
Kai Didschuneit - Réponse Partager
Hi there!
The screen replacement works great with this howto.
But - sadly - my phone is now experiencing a huge battery drain. When fully charged it's dead after almost 6 ours. Also the fingerprint-reader is just working when the screen is on.
Does anyone has an idea howto solve this issues?
Thanks in advance!
flux - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 140
Total : 10,805
