Introduction
Replace the power fuse for the Onkyo TX800 receiver.
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Ajouter un commentaire
Remove the top screw on the back panel. Remove the top screw on the back panel.
  • Remove the top screw on the back panel.
Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
  • Slide off the case to expose the internal components of the receiver.
Locate the fuse. Locate the fuse.
  • Locate the fuse.
Gently wedge a small screwdriver in between one side of the fuse and the contact. Remove the fuse with your thumb and forefinger.
  • Gently wedge a small screwdriver in between one side of the fuse and the contact.
  • Remove the fuse with your thumb and forefinger.
Examine the fuse. If the wire within it is broken, you will need to replace it with a new, 125 Volt, 4 Amp fuse.
  • Examine the fuse. If the wire within it is broken, you will need to replace it with a new, 125 Volt, 4 Amp fuse.
Ligne d'arrivée
4 autre(s) ont terminé cette réparation.
Michael Lady
Membre depuis le 09/04/2010
238 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 27-92, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 membres
7 tutoriels rédigés
Thanks for clear instructions!
Andy Dersch - Réponse
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 37
30 derniers jours : 158
Total : 7,601
