Introduction
Use this guide to remove the blades from the blender in order to replace them.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
First, remove the blender container from the Blender Base, by grabbing the handle and lifting up. First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
Ajouter un commentaire
Next, remove the lid from the Blender Container. Next, remove the lid from the Blender Container.
  • Next, remove the lid from the Blender Container.
Flip the container on its side so that the bottom faces you. Now rotate the bottom counter-clockwise to remove it from the container.
  • Flip the container on its side so that the bottom faces you.
  • Now rotate the bottom counter-clockwise to remove it from the container.
Now you will see the bottom of the blender blades once the bottom piece is removed Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  • Now you will see the bottom of the blender blades once the bottom piece is removed
  • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
Now your container is separated.
  • Now your container is separated.
Flip the blender container on its side so that the bottom faces you.
  • Flip the blender container on its side so that the bottom faces you.
  • Now, you can insert the new set of blades into the container.
  • Be careful when handling the blender blades as they are sharp and can cut you.
Dana
Membre depuis le 14/04/2014
602 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-37, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 47
Total : 2,166
