Introduction
The process of removing covers and simple internal components requires minimal technical experience.
Pièces
Aucune pièce nécessaire.
Shut the device off. Lift the top cover of the scanner. Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Ajouter un commentaire
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
Pushing the clip behind the cover piece in, pull the cover piece outwards. Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Remove the two screws on the front of the printer with a T10 screwdriver. The first is inside the power button panel space and the second is across the printer slider.
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
Pull the circuit board from the power button panel space.
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Pull the memory card reader's circuit board out of its slot. Detach the rainbow connector from the back of the circuit board.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Press the clip directly behind the TouchSmart panel and pull the panel up. Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Grip the printer hood and pull upward.
  • Grip the printer hood and pull upward.
To reassemble, simply follow the steps in reverse order.
7 autre(s) ont terminé cette réparation.
Renee Lamb
Membre depuis le 26/09/2012
208 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 2-11, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 membres
6 tutoriels rédigés
Excellent helpful easy to follow instructions. Thanks.
In step 7, removal of the Touch Pad, I was not able to locate the release clip. Feeling around, what I thought was the latch was a ribbon cable that I distorted but didn't destroy. The top came off without the Touch Pad removal. Once the top was off, I located a latch on the back right of the Touch Pad, but once released, it didn't help to free up the Touch Pad. I couldn't get the Touch Pad off.
Ken - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 56
Total : 8,289
