Aller au contenu principal
PDP Afterglow Wired Xbox 360 Controller Button Replacement
Ce dont vous avez besoin
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: étape 1, image 1 de 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: étape 1, image 2 de 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: étape 3, image 1 de 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: étape 4, image 1 de 1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: étape 5, image 1 de 2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: étape 5, image 2 de 2
    • Push up on the buttons from the front and pull them out from the back.
3 autres ont terminé cette réparation.
Joi Officer
Membre depuis le 09/17/15
283 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-1, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 membres
5 tutoriels rédigés
3 commentaires
What about removing the Dpad? i really need help.
Elijah Douglas - Réponse
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Réponse
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 40
Total : 4,964
