Aller au contenu principal
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Ce dont vous avez besoin
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: étape 1, image 1 de 1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 2, image 1 de 1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 3, image 1 de 1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 4, image 1 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 4, image 2 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 4, image 3 de 3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 5, image 1 de 2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 5, image 2 de 2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 6, image 1 de 1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 7, image 1 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 7, image 2 de 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: étape 7, image 3 de 3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Ligne d'arrivée
Dillon Earl Jones
Membre depuis le 09/28/21
149 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 78
Total : 2,633
