Introduction
This guide will show you how to remove the PSP's housing/frame.
Pièces
Aucune pièce nécessaire.
Turn the PSP over so its back is facing you.
  • Turn the PSP over so its back is facing you.
Ajouter un commentaire
Locate the battery casing button on the rear-left side of the PSP. Press down the button and remove the battery cover.
  • Locate the battery casing button on the rear-left side of the PSP.
  • Press down the button and remove the battery cover.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Using your finger, remove the battery upwards from the system as shown. Using your finger, remove the battery upwards from the system as shown.
  • Using your finger, remove the battery upwards from the system as shown.
Remove the four screws shown with a Phillips #00 screwdriver. You will have to peel back the guarantee sticker to access the screw on the lower left.
  • Remove the four screws shown with a Phillips #00 screwdriver.
  • You will have to peel back the guarantee sticker to access the screw on the lower left.
Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
Squib - Réponse
Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
  • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
  • Remove screws from back righthand side within the holes.
Gently separate the outer plastic casing from the rest of the system as shown. Gently separate the outer plastic casing from the rest of the system as shown.
  • Gently separate the outer plastic casing from the rest of the system as shown.
24 autre(s) ont terminé cette réparation.
Henry Lee
Membre depuis le 14/01/2010
545 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 5-6, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 membres
6 tutoriels rédigés
Thank you! Awesome help!
Jay Vee - Réponse
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 38
30 derniers jours : 166
Total : 23,261
