Introduction
Does your PSP 300xc fail to charge? Get jacked in and get back into the game with a new power jack.
Press the button securing the battery door to the PSP 300xc, and lift the battery door off. Lift the battery out of the PSP.
  • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
  • Lift the battery out of the PSP.
Ajouter un commentaire
Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
Remove four Phillips screws from the back of the PSP. Remove four Phillips screws from the back of the PSP.
  • Remove four Phillips screws from the back of the PSP.
Remove two Phillips screws from the top of the PSP.
  • Remove two Phillips screws from the top of the PSP.
Remove a single screw from the bottom edge of the PSP.
  • Remove a single screw from the bottom edge of the PSP.
Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it. Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
Remove a single Phillips screw securing the home bar to the PSP 300xc.
  • Remove a single Phillips screw securing the home bar to the PSP 300xc.
Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly. Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
  • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
Insert a spudger under the LCD, beside the black plastic tab.
  • Insert a spudger under the LCD, beside the black plastic tab.
  • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables. Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors: Home bar cable
  • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
  • Be sure you are prying up on the retaining flap, not the socket itself
  • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
Remove the LCD from the PSP 300xc.
  • Remove the LCD from the PSP 300xc.
Lift the home bar up as high as it will go, but not so high that the wires disconnect. Try to bend the small tab under the silver rim as little as possible it the following steps.  The more you bend, the more likely it will snap. Twist the home bar counter clockwise while carefully lifting it further.  The left edge has to lift over the black plastic frame to allow it to rotate.
  • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
  • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
  • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
  • The home bar should now lift out of the PSP 300xc.
Remove both trigger buttons by lifting them off the PSP 300xc. Remove both trigger buttons by lifting them off the PSP 300xc.
  • Remove both trigger buttons by lifting them off the PSP 300xc.
Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
  • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
  • Pull the ribbon cable out of its socket.
Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
  • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
  • Remove the power switch board from the PSP.
Remove a single Phillips screw securing the power jack to the PSP.
  • Remove a single Phillips screw securing the power jack to the PSP.
Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
  • Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
  • Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
Matthew Newsom
Membre depuis le 05/01/2010
31 461 Réputation
93 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 66
Total : 4,111
