Aller au contenu principal
Palm TX Back Panel Replacement
Ce dont vous avez besoin
  1. Palm TX Back Panel Replacement, Back Panel: étape 1, image 1 de 2 Palm TX Back Panel Replacement, Back Panel: étape 1, image 2 de 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Back Panel Replacement: étape 2, image 1 de 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Back Panel Replacement: étape 3, image 1 de 2 Palm TX Back Panel Replacement: étape 3, image 2 de 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Back Panel Replacement: étape 4, image 1 de 2 Palm TX Back Panel Replacement: étape 4, image 2 de 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Back Panel Replacement: étape 5, image 1 de 2 Palm TX Back Panel Replacement: étape 5, image 2 de 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
Spencer Lewson
Membre depuis le 01/19/11
793 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-15, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,555
