Unscrew the two 7.35mm Torx T6 screws.
  • Unscrew the two 7.35mm Torx T6 screws.
Ajouter un commentaire
Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
  • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Antonio
Membre depuis le 23/01/2011
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-21, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,209
