Aller au contenu principal
Palm Zire 31 Speaker Replacement
Ce dont vous avez besoin
  1. Palm Zire 31 Speaker Replacement, Case: étape 1, image 1 de 1
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Speaker Replacement: étape 2, image 1 de 1
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Speaker Replacement: étape 3, image 1 de 1
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Speaker Replacement: étape 4, image 1 de 1
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Speaker Replacement, Speaker: étape 5, image 1 de 1
    • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
    • Desolder the speaker wires and solder the new speaker in its place.
    • The black and red wires are connected to the two solder bulbs in the yellow box.
Gabe
Membre depuis le 01/23/11
501 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-21, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 593
