Aller au contenu principal
Palm m 100 Cover Replacement
Ce dont vous avez besoin
  1. Palm m 100 Cover Replacement, Cover: étape 1, image 1 de 1
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: étape 2, image 1 de 1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: étape 3, image 1 de 3 Palm m 100 Cover Replacement: étape 3, image 2 de 3 Palm m 100 Cover Replacement: étape 3, image 3 de 3
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: étape 4, image 1 de 1
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: étape 5, image 1 de 1
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: étape 6, image 1 de 1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Anne Carey
Membre depuis le 10/25/11
1 Réputation
3 tutoriels rédigés
Équipe
James Madison, Team 1-3, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 537
