Introduction
Before you begin disassembly, be sure to have the necessary tools. You will need a Torx size T6 screwdriver, tweezers, and the device opening tool. You will be removing the stylus, the back panel, and the battery in order to access the motherboard.
Ce dont vous avez besoin
Use tweezers to unplug the battery cable from the motherboard socket.
Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
Use the plastic opening tool to pry the orange clamp away from the motherboard.
Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
