Aller au contenu principal
Panasonic Camera DMC FX37 Battery Door Replacement
Ce dont vous avez besoin
  1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: étape 1, image 1 de 2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: étape 1, image 2 de 2
    • Set the switch on the battery door to "open," and open the door.
  2. Panasonic Camera DMC FX37 Battery Door Replacement: étape 2, image 1 de 1
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Panasonic Camera DMC FX37 Battery Door Replacement: étape 3, image 1 de 1
    • Push the metal bar down using the metal tweezers.
  4. Panasonic Camera DMC FX37 Battery Door Replacement: étape 4, image 1 de 1
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Panasonic Camera DMC FX37 Battery Door Replacement: étape 5, image 1 de 1
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
Zhentao
Membre depuis le 01/30/18
247 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team S2-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 4
Total : 254
