Introduction
The SD card stores videos and images that you record on your camera. You should remove the battery and SD card before opening the camera to access the screen,motherboard, flash, lens, or any other internal part of the camera.
Slide the bottom panel in the direction of the arrow on the panel.
  • Slide the bottom panel in the direction of the arrow on the panel.
Ajouter un commentaire
Pull/lift open the battery cover in the direction directly away from the camera.
  • Pull/lift open the battery cover in the direction directly away from the camera.
Push down on the SD card next to the battery in order to release the SD card.
  • Push down on the SD card next to the battery in order to release the SD card.
  • Pull the SD memory card out of the camera in the same way that you would pull out the battery.
Zoe Hinck
Membre depuis le 12/04/2012
29 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-19, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 791
