Aller au contenu principal
Panasonic DVD-RV31 Player Front Panel Replacement
Ce dont vous avez besoin
  1. Panasonic DVD-RV31 Player Front Panel Replacement, Disk Tray Cover: étape 1, image 1 de 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Front Panel Replacement: étape 2, image 1 de 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: étape 3, image 1 de 2 Panasonic DVD-RV31 Player Front Panel Replacement, Outer Case: étape 3, image 2 de 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic DVD-RV31 Player Front Panel Replacement: étape 4, image 1 de 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: étape 5, image 1 de 2 Panasonic DVD-RV31 Player Front Panel Replacement, Front Panel: étape 5, image 2 de 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Kevin
Membre depuis le 04/26/11
375 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 18-20, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 2,517
