Pièces
Aucune pièce nécessaire.
Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
  • Remove 3 screws running along back edge of case cover.
  • Remove 2 screws from each side of case cover.
Ajouter un commentaire
Grab edges of cover, pull outward slightly, and pull straight up.
  • Grab edges of cover, pull outward slightly, and pull straight up.
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Grip jogger dial and lift up. It should come off easily. Grip jogger dial and lift up. It should come off easily.
  • Grip jogger dial and lift up. It should come off easily.
Remove 4 mounting screws as shown. Unscrew and save brass tab. Push in 2 plastic retainers and lift out.
  • Remove 4 mounting screws as shown.
  • Unscrew and save brass tab.
  • Push in 2 plastic retainers and lift out.
Kevin
Membre depuis le 26/04/2011
351 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 18-20, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,027
