Aller au contenu principal
Panasonic Lumix DMC-FX01 LCD Screen Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-FX01 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 2, image 1 de 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 3, image 1 de 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 LCD Screen Replacement, Rear Casing: étape 4, image 1 de 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 5, image 1 de 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 6, image 1 de 2 Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 6, image 2 de 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 8, image 1 de 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 9, image 1 de 2 Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 9, image 2 de 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 LCD Screen Replacement, LCD Screen: étape 10, image 1 de 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 LCD Screen Replacement: étape 11, image 1 de 1
    • Gently tug the thicker ribbon to remove it from its housing.
3 autres ont terminé cette réparation.
Andrew
Membre depuis le 10/11/10
396 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-22, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 16
Total : 17,113
