Introduction
This guide will take you through the steps of how to replace the flash assembly.
Pièces
Aucune pièce nécessaire.
Move the switch on the battery door to the Open position.
  • Move the switch on the battery door to the Open position.
  • The door will automatically swing open after you let it go.
Ajouter un commentaire
Push the small gray tab on the top right corner to the left. The battery will pop out slightly. Keep your finger clear of the battery when it pops out.
  • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
  • Keep your finger clear of the battery when it pops out.
Push the memory card in and let go.
  • Push the memory card in and let go.
  • The memory card will pop out slightly.
  • Pull out the memory card.
Unscrew the small screws on the sides of the camera. The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  • Unscrew the small screws on the sides of the camera.
  • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
Unscrew the three small screws on the bottom(#00P, 3.3mm). The bottom will fall off.
  • Unscrew the three small screws on the bottom(#00P, 3.3mm).
  • The bottom will fall off.
Lift up the bottom back cover by prying the bottom edge with the spudger. Gently lift up the back cover with your hand from the bottom to the top. Gently lift up the back cover with your hand from the bottom to the top.
  • Lift up the bottom back cover by prying the bottom edge with the spudger.
  • Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors.
  • Lift the tabs on the ZIF connectors.
  • The ribbon cables should easily come out of the ZIF connectors.
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover. Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
  • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
  • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
Unscrew the small screws beneath the top cover(#00P, 1.7mm).
  • Unscrew the small screws beneath the top cover(#00P, 1.7mm).
Lift the logic board out with your hand by pushing the tabs out and pulling the logic board up. The on/off switch and the anti-shake button may fall out. The on/off switch and the anti-shake button may fall out.
  • Lift the logic board out with your hand by pushing the tabs out and pulling the logic board up.
  • The on/off switch and the anti-shake button may fall out.
The flash assembly is hardwired into the top circuit board.
  • The flash assembly is hardwired into the top circuit board.
Karissa
Membre depuis le 13/04/2012
50 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 355
