Introduction
If you have not disassembled a device similar to this in the past, here are a few tips:
1) Always place the screws you remove with their respective slots, this will prevent you from trying to insert a screw that is too big and causing internal damage. (A magnetic mat can help with this!)
2) Because this is a smaller device and you will be interacting with some of the circuit boards directly, you may wish to wear an anti-static wrist wrap to prevent damage.
3) Ribbon cables (named due to their shape) are quite delicate and should be handled gently if possible. We will be sure to warn you when dealing with these.
Otherwise, this guide will mainly be unscrewing screws.
Pièces
Aucune pièce nécessaire.
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel. Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
Ajouter un commentaire
Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely. Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
On the opposite side of the camera, remove the two 3 mm screws. Remove the bottom side panel and place it with its respective 3 mm screw.
  • On the opposite side of the camera, remove the two 3 mm screws.
  • Remove the bottom side panel and place it with its respective 3 mm screw.
Remove the front panel (the panel around the lens casing) from the camera. Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord. Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
  • Remove the front panel (the panel around the lens casing) from the camera.
  • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
  • Remove the back panel from the camera.
Remove the top control panel (connected to the flash battery) from the camera.
  • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
Jackson O'DOnnell
Membre depuis le 30/01/2018
271 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S2-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 26
