Aller au contenu principal
Panasonic Lumix DMC-FX37 Disassembly
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 1 de 2 Panasonic Lumix DMC-FX37 Disassembly, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 2 de 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Disassembly: étape 2, image 1 de 2 Panasonic Lumix DMC-FX37 Disassembly: étape 2, image 2 de 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Disassembly: étape 3, image 1 de 2 Panasonic Lumix DMC-FX37 Disassembly: étape 3, image 2 de 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Disassembly: étape 4, image 1 de 3 Panasonic Lumix DMC-FX37 Disassembly: étape 4, image 2 de 3 Panasonic Lumix DMC-FX37 Disassembly: étape 4, image 3 de 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Disassembly: étape 5, image 1 de 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
Jackson O'DOnnell
Membre depuis le 01/30/18
283 Réputation
1 tutoriel rédigé
Équipe
Baylor, Team S2-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 8
Total : 589
