Aller au contenu principal
Panasonic Lumix DMC-FX37 Photoreceptor Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 1 de 2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 2 de 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 2, image 1 de 2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 2, image 2 de 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 3, image 1 de 2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 3, image 2 de 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 4, image 1 de 3 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 4, image 2 de 3 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 4, image 3 de 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 5, image 1 de 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Photoreceptor: étape 6, image 1 de 2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Photoreceptor: étape 6, image 2 de 2
    • Locate and remove the silver 2mm screw on the protection panel.
    • Remove the three black 8mm screws that remain.
    • Be sure to remember which length of screw goes to which slot. Failing to do so could damage your device.
    • Proceed to remove the protection panel entirely.
  7. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 7, image 1 de 1
    • Insert the flat end of a plastic spudger underneath the motherboard and twist. This will disconnect the board from the device and allow it to be removed.
  8. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 8, image 1 de 1
    • Use the pointed end of the spudger to lift the black tabs holding the ribbon cable connected to the photoreceptor in place.
    • Before pulling the cable free, be sure to complete the next step (removing the screws) as the ribbon cables are delicate and must be handled with care.
  9. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 9, image 1 de 2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: étape 9, image 2 de 2
    • Remove the three 3mm screws holding the photoreceptor in place.
    • Carefully lift the photoreceptor, disconnecting the ribbon cable and remove the photoreceptor from the device.
Zhentao
Membre depuis le 01/30/18
247 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team S2-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 265
