Introduction
The flash unit is attached to the inner casing of the camera.
Pièces
Aucune pièce nécessaire.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Ajouter un commentaire
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Remove the back casing from the camera.
  • Remove the back casing from the camera.
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
  • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
  • Carefully remove the function switch cover. This unit snaps on and off.
Carefully unsnap the front logic board from the rear logic board using a spudger.
  • Carefully unsnap the front logic board from the rear logic board using a spudger.
Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
  • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
  • This leaves you with the logic board and the top connection panel separate and free from the camera
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Remove the 3 screws holding the lens assembly in place.
  • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
Remove the entire assembly out of the casing. The ribbons on the left and bottom of the assembly simply rest on the camera housing.
  • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
Use the spudger to unclip the top ribbon cable from the circuit board.
  • Use the spudger to unclip the top ribbon cable from the circuit board.
Remove the single 2mm screw in the bottom right corner of the circuit board
  • Remove the single 2mm screw in the bottom right corner of the circuit board
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove. The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
    • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
Take note of how the slots fit into the circuit board for easy replacement.
  • Take note of how the slots fit into the circuit board for easy replacement.
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
  • Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
Remove the front casing from the rest of the device.
  • Remove the front casing from the rest of the device.
Use a spudger to carefully lift the small clip located to the left of the unit. Lift the flash unit out of the case.
  • Use a spudger to carefully lift the small clip located to the left of the unit.
  • Lift the flash unit out of the case.
2 autre(s) ont terminé cette réparation.
Guadalupe
Membre depuis le 11/10/2010
90 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-21, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 membres
7 tutoriels rédigés
Very easy to follow instructions. Thank you very much!!!
Mike Hair - Réponse
Thank you for showing me how to fix my LUMIX TZ5 Camera.. I will do this as soon as I get the replacement flash.
Carlos
marooned7777 - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 13,354
