Aller au contenu principal
Panasonic SA-HT810V DVD Drive Replacement
Ce dont vous avez besoin
  1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: étape 1, image 1 de 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: étape 1, image 2 de 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: étape 1, image 3 de 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
  2. Panasonic SA-HT810V DVD Drive Replacement: étape 2, image 1 de 2 Panasonic SA-HT810V DVD Drive Replacement: étape 2, image 2 de 2
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
  3. Panasonic SA-HT810V DVD Drive Replacement: étape 3, image 1 de 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Panasonic SA-HT810V DVD Drive Replacement: étape 4, image 1 de 3 Panasonic SA-HT810V DVD Drive Replacement: étape 4, image 2 de 3 Panasonic SA-HT810V DVD Drive Replacement: étape 4, image 3 de 3
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
  5. Panasonic SA-HT810V DVD Drive Replacement: étape 5, image 1 de 1
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Panasonic SA-HT810V DVD Drive Replacement: étape 6, image 1 de 2 Panasonic SA-HT810V DVD Drive Replacement: étape 6, image 2 de 2
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
  7. Panasonic SA-HT810V DVD Drive Replacement: étape 7, image 1 de 1
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
  8. Panasonic SA-HT810V DVD Drive Replacement: étape 8, image 1 de 1
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
2 autres ont terminé cette réparation.
Nathan Cheadle
Membre depuis le 04/15/10
161 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 16-5, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,410
