Aller au contenu principal
Panasonic SA-PM17 CD Tray Cover Replacement
Ce dont vous avez besoin
  1. Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: étape 1, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: étape 1, image 2 de 2
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
  2. Panasonic SA-PM17 CD Tray Cover Replacement: étape 2, image 1 de 1
    • Remove these seven 11.5 mm screws and place aside.
  3. Panasonic SA-PM17 CD Tray Cover Replacement: étape 3, image 1 de 1
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
  4. Panasonic SA-PM17 CD Tray Cover Replacement: étape 4, image 1 de 1
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
  5. Panasonic SA-PM17 CD Tray Cover Replacement: étape 5, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement: étape 5, image 2 de 2
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
  6. Panasonic SA-PM17 CD Tray Cover Replacement: étape 6, image 1 de 1
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
  7. Panasonic SA-PM17 CD Tray Cover Replacement: étape 7, image 1 de 1
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  8. Panasonic SA-PM17 CD Tray Cover Replacement: étape 8, image 1 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 8, image 2 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
  9. Panasonic SA-PM17 CD Tray Cover Replacement: étape 9, image 1 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 9, image 2 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 9, image 3 de 3
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
  10. Panasonic SA-PM17 CD Tray Cover Replacement: étape 10, image 1 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 10, image 2 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 10, image 3 de 3
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
  11. Panasonic SA-PM17 CD Tray Cover Replacement: étape 11, image 1 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 11, image 2 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 11, image 3 de 3
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  12. Panasonic SA-PM17 CD Tray Cover Replacement: étape 12, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement: étape 12, image 2 de 2
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  13. Panasonic SA-PM17 CD Tray Cover Replacement: étape 13, image 1 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 13, image 2 de 3 Panasonic SA-PM17 CD Tray Cover Replacement: étape 13, image 3 de 3
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
  14. Panasonic SA-PM17 CD Tray Cover Replacement: étape 14, image 1 de 1
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
  15. Panasonic SA-PM17 CD Tray Cover Replacement, CD Tray Cover: étape 15, image 1 de 1
    • Remove the two 11.5 mm screws indicated and set aside in a safe place.
  16. Panasonic SA-PM17 CD Tray Cover Replacement: étape 16, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement: étape 16, image 2 de 2
    J'achète
    • Using tweezers, remove the two restraints indicated and place with the screws removed in the previous step.
  17. Panasonic SA-PM17 CD Tray Cover Replacement: étape 17, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement: étape 17, image 2 de 2
    • Remove the spring from its slot using tweezers.
  18. Panasonic SA-PM17 CD Tray Cover Replacement: étape 18, image 1 de 1
    • Using tweezers or fingers, pull firmly on the base of this cord until it pops out of its slot.
  19. Panasonic SA-PM17 CD Tray Cover Replacement: étape 19, image 1 de 2 Panasonic SA-PM17 CD Tray Cover Replacement: étape 19, image 2 de 2
    • Lift the pegs of the cover up while rotating the rest of the part down and out of the device.
    • If at first the cover does not come free, wiggle it around a bit until it does, but do not force it out.
    • Do not to lose this spring while replacing the cover.
NathanB
Membre depuis le 04/13/11
418 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 4-1, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 26
Total : 4,863
