Introduction
This guide will show you how to gain access to and replace the track pad board in your Panasonic CF-29.
Locate the bay door for the battery on the left side of the laptop.
  • Locate the bay door for the battery on the left side of the laptop.
Ajouter un commentaire
Slide the latch to the right and then down to unlock it. Pull out the battery.
  • Slide the latch to the right and then down to unlock it.
  • Pull out the battery.
Locate the door for the hard drive on the right side of the laptop
  • Locate the door for the hard drive on the right side of the laptop
Push and slide the latch up to open the hard drive door. Pull out the hard drive.
  • Push and slide the latch up to open the hard drive door.
  • Pull out the hard drive.
Flip the device upside down with the handle facing away from you.
  • Flip the device upside down with the handle facing away from you.
  • Open the optical drive bay by sliding its latch to the right.
  • Locate optical drive release mechanism on the bottom of the laptop.
Slide the latch cover to the right.
  • Slide the latch cover to the right.
Push the exposed switch to the left to eject the optical drive. Push the exposed switch to the left to eject the optical drive.
  • Push the exposed switch to the left to eject the optical drive.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Begin by turning the laptop upside down with the handle towards you.
  • Begin by turning the laptop upside down with the handle towards you.
  • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
  • Remove the panel and set it aside.
  • Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Be careful when lifting the cover as you may damage some connections.
  • Be careful when lifting the cover as you may damage some connections.
  • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Now the back cover should be off and you can access the inside of the casing.
  • Now the back cover should be off and you can access the inside of the casing.
Locate the track pad chip near the handle.
  • Locate the track pad chip near the handle.
  • Remove the upper right screw.
Use a pry bar to detach the white ribbon cable shown.
  • Use a pry bar to detach the white ribbon cable shown.
  • Push the brown tab to release the cable
Remove the screw that was previously concealed under the now removed ribbon cable.
  • Remove the screw that was previously concealed under the now removed ribbon cable.
Remove the rightmost ribbon cable
  • Remove the rightmost ribbon cable
    • Pry up the brown clip
    • Tug the cable out
Pull the track pad slightly up and to the right.
  • Pull the track pad slightly up and to the right.
  • Do not completely remove the circuit board because it is still attached.
Remove the last ribbon cable.
  • Remove the last ribbon cable.
    • Pry up on the brown part to release the ribbon cable.
You have successfully removed the track pad board.
  • You have successfully removed the track pad board.
Dylan Bloom
Membre depuis le 12/04/2010
262 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 27-93, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 membres
12 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 5,275
