Introduction
Use this guide to replace the foam hull of the Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Pièces
Aucune pièce nécessaire.
Vidéo d'introduction
Peel off double sided tape and apply to one side of the broken hull. Peel off double sided tape and apply to one side of the broken hull.
  • Peel off double sided tape and apply to one side of the broken hull.
Ajouter un commentaire
Cut the tape with scissors as close to the shape of the broken hull as possible. Cut the tape with scissors as close to the shape of the broken hull as possible.
  • Cut the tape with scissors as close to the shape of the broken hull as possible.
Peel off the other side of the tape and stick the two sides together. Peel off the other side of the tape and stick the two sides together.
  • Peel off the other side of the tape and stick the two sides together.
David Hoyt
Membre depuis le 09/04/2010
3 599 Réputation
44 tutoriels rédigés
Équipe
Cal Poly, Team 25-89, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 membres
52 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 18
Total : 1,092
