Aller au contenu principal
Parrot AR.Drone 2.0 Motor Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: étape 1, image 1 de 2 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: étape 1, image 2 de 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: étape 2, image 1 de 2 Parrot AR.Drone 2.0 Motor Replacement: étape 2, image 2 de 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: étape 3, image 1 de 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: étape 4, image 1 de 3 Parrot AR.Drone 2.0 Motor Replacement: étape 4, image 2 de 3 Parrot AR.Drone 2.0 Motor Replacement: étape 4, image 3 de 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: étape 5, image 1 de 2 Parrot AR.Drone 2.0 Motor Replacement, Motor: étape 5, image 2 de 2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: étape 6, image 1 de 1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: étape 7, image 1 de 1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: étape 8, image 1 de 2 Parrot AR.Drone 2.0 Motor Replacement: étape 8, image 2 de 2
    • Carefully wiggle out the motor assembly out of the arm.
5 autres ont terminé cette réparation.
David Hoyt
Membre depuis le 04/09/10
4 023 Réputation
43 tutoriels rédigés
Équipe
Cal Poly, Team 25-89, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 membres
63 tutoriels rédigés
2 commentaires
are the motors different on each side?
dbksoft - Réponse
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 5,687
