Introduction
I go step by step through how to replace an input jack on the Peavy XM4 Amp/Mixer
There are two screws at the top and two at the bottom
  • There are two screws at the top and two at the bottom
Ajouter un commentaire
All of the dials have a rubber cover and a nut, these need to be removed from all of the dials.  The Jack inputs also have a nut holding them in place, remove these also. All of the dials have a rubber cover and a nut, these need to be removed from all of the dials.  The Jack inputs also have a nut holding them in place, remove these also.
  • All of the dials have a rubber cover and a nut, these need to be removed from all of the dials. The Jack inputs also have a nut holding them in place, remove these also.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier. Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
  • Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
  • Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
  • Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
Josh Walford
Membre depuis le 12/01/2018
157 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5
