Introduction
This guide will teach you how to properly remove the cover of the camera.
Pièces
Aucune pièce nécessaire.
Remove the following screws: Two silver 3.15mm Phillips #00 screws on the right side of the camera
  • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
Ajouter un commentaire
Remove the two indicated screws on the bottom of the camera:
  • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Carefully pull the back of casing away from the front. Carefully pull the back of casing away from the front.
  • Carefully pull the back of casing away from the front.
After removing the back cover, several things must be removed. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  • After removing the back cover, several things must be removed.
  • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Nicole Wong
Membre depuis le 30/01/2011
329 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-29, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,919
