Introduction
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
Pry off the four white feet with the pointed end of the spudger
  • Pry off the four white feet with the pointed end of the spudger
Ajouter un commentaire
Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
  • The connectors on the panel are fragile and may break.
Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
  • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
  • The cables do not have a lot of slack in them. Be careful not to break the connectors.
  • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
Separate the white suport bracket from the headphone/power electronics board.
  • Separate the white suport bracket from the headphone/power electronics board.
Graham Rolph
Membre depuis le 18/04/2013
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-48, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 904
