Introduction
In this guide, we are going to detach the disc tray from the device.
Pièces
Aucune pièce nécessaire.
Remove four 7.5 mm Phillips screws on the both sides (2 on each side). Remove five 7.5 mm Phillips screws on the back of the player.
  • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
  • Remove five 7.5 mm Phillips screws on the back of the player.
Ajouter un commentaire
Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
Remove two 7.5 mm screws, one on each side of the player. Remove three 7.5mm screws from the bottom of the player.
  • Remove two 7.5 mm screws, one on each side of the player.
  • Remove three 7.5mm screws from the bottom of the player.
  • Note that the three screws from the bottom are slightly different screws.
Detach all the ribbon wires (4) attached to the motherboard
  • Detach all the ribbon wires (4) attached to the motherboard
The first 3 ribbon wires can be removed by grasping near the head and gently pulling up. Locate the skinny fourth ribbon wire near the top right of the motherboard. Remove the fourth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull the black clip up, insert the ribbon ribbon, and push the black clip back down.
  • The first 3 ribbon wires can be removed by grasping near the head and gently pulling up.
  • Locate the skinny fourth ribbon wire near the top right of the motherboard.
  • Remove the fourth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull the black clip up, insert the ribbon ribbon, and push the black clip back down.
  • Be firm, but gentle when pulling to avoid pulling the wires off the head.
Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
  • Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
  • Remove the 12 mm Phillips screw that secures the tray to the upright metal frame.
  • Remove the two 7.5 mm Phillips screws that attach the disc tray to the motherboard and front panel.
Gently pull forward and upward to free disc tray.
  • Gently pull forward and upward to free disc tray.
Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
  • Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
4 autre(s) ont terminé cette réparation.
Toby Goldsteinholm
Membre depuis le 09/10/2011
273 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-20, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 membres
5 tutoriels rédigés
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
Steve Emerson - Réponse
I failed huhuhu
Hello kitty - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 25
30 derniers jours : 90
Total : 6,923
