Introduction
Use this guide to replace your headset's motherboard
Flip the headset face down. Squeeze both sides of the battery cover. While squeezing, pull the cover up slowly to remove it.
  • Flip the headset face down.
  • Squeeze both sides of the battery cover.
  • While squeezing, pull the cover up slowly to remove it.
Ajouter un commentaire
Locate and detatch the white connector that connects the wires of the battery to the wires of the headset. Locate and detatch the white connector that connects the wires of the battery to the wires of the headset. Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components. Apply additional heat at the tip of the microphone.
  • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
  • Apply additional heat at the tip of the microphone.
After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset. Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
  • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
Remove the microphone from the tip of the plastic. You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  • Remove the microphone from the tip of the plastic.
  • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
Use the heat gun to melt the adhesive connecting the headset face to the speaker casing. Use the plastic opening tool to separate the speaker casing from the headset face.
  • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
  • Use the plastic opening tool to separate the speaker casing from the headset face.
  • Add extra heat to the sides to melt the adhesive between the plastic connectors.
Slowly separate the motherboard from the rest of the headset. Slowly separate the motherboard from the rest of the headset.
  • Slowly separate the motherboard from the rest of the headset.
Locate the microphone wires on the bottom of the motherboard.
  • Locate the microphone wires on the bottom of the motherboard.
  • Use a hairdryer or heat gun to melt the glue off of the motherboard.
Flip the device over.
  • Flip the device over.
  • Use a soldering iron to remove the solder that holds the wires to the motherboard.
  • For help soldering, click here.
  • The microphone piece should be completely detached from the motherboard.
Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers. Using a plastic opening tool, prop open the edges. Gently pull the black speaker casing up to remove it.
  • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
  • Using a plastic opening tool, prop open the edges.
  • Gently pull the black speaker casing up to remove it.
Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard. The wires should come off as they are not soldered to the motherboard.
  • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
  • The wires should come off as they are not soldered to the motherboard.
Joe
Membre depuis le 12/04/2012
79 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-29, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 722
