Introduction
The base unit and headset are synchronized together when you bought them. So if you want to use a replacement headset with the base unit (or if you lose your connection to the base unit) you will need to follow these steps to synchronize the headset to the base:
Ensure the headset is in the base's cradle.
  • Ensure the headset is in the base's cradle.
Ajouter un commentaire
Press the volume control buttons on the back of the base until the front of the base flashes red.
  • Press the volume control buttons on the back of the base until the front of the base flashes red.
Press the mute switch on top of the headset until the green light on the headset turns on.
  • Press the mute switch on top of the headset until the green light on the headset turns on.
Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord. Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord.
  • Unplug the power cord for five seconds. After the five seconds are over, reconnect the power cord.
When the flashing red light becomes solid, synchronization is complete.
  • When the flashing red light becomes solid, synchronization is complete.
Ligne d'arrivée
2 autre(s) ont terminé cette réparation.
Joe
Membre depuis le 12/04/2012
63 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-29, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 1,621
