Aller au contenu principal
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: étape 1, image 1 de 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: étape 1, image 2 de 2
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
  2. Plantronics CS50 Headset System Reset: étape 2, image 1 de 1
    • Press the call control button again.
  3. Plantronics CS50 Headset System Reset: étape 3, image 1 de 2 Plantronics CS50 Headset System Reset: étape 3, image 2 de 2
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
Ligne d'arrivée
3 autres ont terminé cette réparation.
Joe
Membre depuis le 04/12/12
99 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 17-29, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 membres
7 tutoriels rédigés
4 commentaires
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Réponse
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Réponse
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Réponse
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 58
Total : 22,278
