Aller au contenu principal
PlayStation 2 Optical Disc Drive Lens Cleaning
Ce dont vous avez besoin
  1. PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: étape 1, image 1 de 3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: étape 1, image 2 de 3 PlayStation 2 Optical Disc Drive Lens Cleaning, Top Cover: étape 1, image 3 de 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Optical Disc Drive Lens Cleaning: étape 2, image 1 de 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Optical Disc Drive Lens Cleaning: étape 3, image 1 de 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Optical Disc Drive Lens Cleaning: étape 4, image 1 de 2 PlayStation 2 Optical Disc Drive Lens Cleaning: étape 4, image 2 de 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
  5. PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: étape 5, image 1 de 2 PlayStation 2 Optical Disc Drive Lens Cleaning, PlayStation 2 Optical Disc Drive Lens Cleaning: étape 5, image 2 de 2
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
  6. PlayStation 2 Optical Disc Drive Lens Cleaning: étape 6, image 1 de 1
    • Carefully wipe the lens in a circular motion with a rubbing alcohol damped Q-Tip.
    • Do not over-dampen the Q-Tip with rubbing alcohol.
    • Allow a few minutes for the rubbing alcohol to evaporate.
63 autres ont terminé cette réparation.
emessers
Membre depuis le 10/28/09
2 700 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 19-1, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 membres
34 tutoriels rédigés
10 commentaires
I've tried the steps mentioned above to no avail. The problem persist. Anything else i can do besides purchasing another console? Sentimental value.Thank you.
Albie - Réponse
What I'm gonna try and do is take a laser from a PC DVD burner tray and see if I reads things. It's a long shot but you can't break what's already broken ehh. I'll let you know what happens. And if it works I will write the proper tutorial for it:)
Yuri weinberg -
HOw to use a lens cleaner dvd in Ps2
sajidsahito110 - Réponse
please answer my problem
Hi
I have problem with my ps2 when I put the cd in the screen says that it's reading the cd but after a few minutes it stops and says no data.
What should I do ? how do I fix it ? And any clues on what to do?
Arif Ali - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 205
30 derniers jours : 944
Total : 108,006
