Aller au contenu principal
PlayStation 3 Slim Laser lens Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: étape 1, image 1 de 2 PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: étape 1, image 2 de 2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  2. PlayStation 3 Slim Laser lens Replacement: étape 2, image 1 de 1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  3. PlayStation 3 Slim Laser lens Replacement: étape 3, image 1 de 1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  4. PlayStation 3 Slim Laser lens Replacement: étape 4, image 1 de 1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  5. PlayStation 3 Slim Laser lens Replacement: étape 5, image 1 de 1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  6. PlayStation 3 Slim Laser lens Replacement: étape 6, image 1 de 2 PlayStation 3 Slim Laser lens Replacement: étape 6, image 2 de 2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
20 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 055 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 506 tutoriels rédigés
5 commentaires
Donde puedo comprar refacciones y partes para PS3 Slim?
David - Réponse
yo vendo amigo = ivaramso@gmail.com para ventas
Ivan Ramirez -
How can this be easy, but the Blu-Ray drive be considered Moderate? You need to complete the Blu-Ray drive removal prior to replacing the laser lens, which means this is at best a Moderate task.
Ben Kevan - Réponse
This is not lens replacement, this is drive replacement. Is there a separate guide for lens replacement?
cmchallam - Réponse
Shows how to do the laser assembly in the video but not how to reinstall it in the drive. Lazy guide. Just buy a whole new drive if you are following this guide.
Beninja - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 40
30 derniers jours : 117
Total : 32,529
