Aller au contenu principal
PlayStation Vita Camera Replacement
Ce dont vous avez besoin
  1. PlayStation Vita Camera Replacement, Case Separation: étape 1, image 1 de 2 PlayStation Vita Camera Replacement, Case Separation: étape 1, image 2 de 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Camera Replacement: étape 2, image 1 de 3 PlayStation Vita Camera Replacement: étape 2, image 2 de 3 PlayStation Vita Camera Replacement: étape 2, image 3 de 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Camera Replacement: étape 3, image 1 de 2 PlayStation Vita Camera Replacement: étape 3, image 2 de 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Camera Replacement: étape 4, image 1 de 3 PlayStation Vita Camera Replacement: étape 4, image 2 de 3 PlayStation Vita Camera Replacement: étape 4, image 3 de 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Camera Replacement: étape 5, image 1 de 2 PlayStation Vita Camera Replacement: étape 5, image 2 de 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Camera Replacement: étape 6, image 1 de 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Camera Replacement: étape 7, image 1 de 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Camera Replacement: étape 8, image 1 de 1
    • Separate the front and rear cases.
  9. PlayStation Vita Camera Replacement, Camera: étape 9, image 1 de 2 PlayStation Vita Camera Replacement, Camera: étape 9, image 2 de 2
    • Release the camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  10. PlayStation Vita Camera Replacement: étape 10, image 1 de 3 PlayStation Vita Camera Replacement: étape 10, image 2 de 3 PlayStation Vita Camera Replacement: étape 10, image 3 de 3
    • Using a spudger, gently pry up the camera.
    • Work your way under the camera and along the camera flex cable, using the pointy tip of the spudger to peel away the adhesive, freeing the camera.
    • Carefully lift and remove the camera.
5 autres ont terminé cette réparation.
Brittany McCrigler
Membre depuis le 03/05/12
89 014 Réputation
131 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 71
Total : 8,635
