Aller au contenu principal
Playstation 3 Fan Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Playstation 3 Fan Replacement, Top Cover: étape 1, image 1 de 2 Playstation 3 Fan Replacement, Top Cover: étape 1, image 2 de 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: étape 2, image 1 de 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: étape 3, image 1 de 2 Playstation 3 Fan Replacement: étape 3, image 2 de 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: étape 4, image 1 de 2 Playstation 3 Fan Replacement: étape 4, image 2 de 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: étape 5, image 1 de 3 Playstation 3 Fan Replacement: étape 5, image 2 de 3 Playstation 3 Fan Replacement: étape 5, image 3 de 3
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: étape 6, image 1 de 2 Playstation 3 Fan Replacement, Power Supply: étape 6, image 2 de 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: étape 7, image 1 de 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: étape 8, image 1 de 2 Playstation 3 Fan Replacement: étape 8, image 2 de 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: étape 9, image 1 de 2 Playstation 3 Fan Replacement, Motherboard Enclosure: étape 9, image 2 de 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: étape 10, image 1 de 2 Playstation 3 Fan Replacement: étape 10, image 2 de 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: étape 11, image 1 de 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: étape 12, image 1 de 3 Playstation 3 Fan Replacement: étape 12, image 2 de 3 Playstation 3 Fan Replacement: étape 12, image 3 de 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: étape 13, image 1 de 1
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
iDeleted
Membre depuis le 07/07/10
2 101 Réputation
39 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 2,801
