Introduction
The Pokemon Go Plus+ uses the same battery replacement as the Nintendo Switch Official Joy-Cons, so finding the battery should be very easy!
Ce dont vous avez besoin
Flanking both sides of the charging port are J00 Screws. Remove these.
When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
Normally you'd disconnect the battery first, but with this device we cannot reach the connector until we remove the battery cover.
This connector is the same one on the Nintendo Joy-Cons, this connector has no retention clip, and must be pried upward to remove it.
The battery is attached to the cover with some adhesive, use your spudger to carefully and gently lever it off the cover.
7 autres ont terminé cette réparation.
6 commentaires de tutoriel
Do you need to solder the wires into the new battery, or is it just a clip system?
There is a connector, it's not soldered. It's the exact same part and connector is the official joycon batteries.
David -
Goodness, I accidently threw mine in de washmachine! It didn't respond to anything, I left it to dry in rice overnight. The next morning I tried to charge it, all the lights lit up and it died with a buzzer. I thought it was gone, I ordered a new one.... Then decided to follow your guide, I bought the battery and gave it a try. It's working again! Thank you so much :D Now I have 2 plusses, I will keep the new one as a back-up, since it looks like they've been discontinued, and the few stores that still sell it have increased the price a lot. Hello inflation!
Thanks again!
Where did you buy your battery from, I am in the same situation mine went for a 40minute trip in the wash machine!
-___-
PokeZed -
